Root Help, ODIN | Download Mode
xL Panda
ok so i have a problem with odin and im not sure what i can do ive tried all the samsung drivers i can find but i always end up with a "Device driver not installed sucessfully".
I then go to device manager and find "SAMSUNG USB Composite Device" and in the properties it Gives me this "This device cannot start. (Code 10)" .
Any Help? Thanks in advance
This happened to me when I first got my phone, and It could be because your computer uses a USB Host controller, I'm not saying that's the problem, but it was mine, so It could be similar.
When you unplug and plug in the phone without safely removing the device, or turning off USB connection, the computer thinks that there's something wrong, and it won't allow it to start.
Go into Device Manager, Universal Serial Bus Controllers and look for a device that says something similar to "Enhanced Host Controller" or "USB Host Controller"
Make sure you unplug the phone from the computer
Then right click it, disable.
Then plug your phone in, if this doesn't work, the just enable the controller back and reinstall drivers.
