Apps Help on my app?
jtrain45
Hello, I'm not sure if this is in the right place, I am new here. Anyway, I need help and advice for my app. I have created(for the most part) a calculator that solves a quadratic equation based on the three numbers the user inputs. I have a calculate button that I want to display the answer when it gets clicked and after it does the calculations. It doesn't display anything. I also have a reset button that will reset the text fields but same problem. I will put my code below this. If you see any other errors please tell me. Thanks
Code:
[CODE]
package android.jackson.com;
import android.app.Activity;
import android.content.Intent;
import android.os.Bundle;
import android.view.KeyEvent;
import android.view.MenuInflater;
import android.view.MenuItem;
import android.view.View;
import android.view.View.OnClickListener;
import android.view.View.OnKeyListener;
import android.widget.Button;
import android.widget.EditText;
import android.widget.TextView;
import android.widget.Toast;
public class myMenu extends Activity {
private EditText editText1;
private EditText editText2;
private EditText editText3;
private Button calcbutton;
private Button resetbutton;
private TextView textView6; // Answer
private OnKeyListener mKeyListener;
// TODO Auto-generated method stub
setContentView(R.layout.main);
/** Called when the activity is first created. */
//reset button will be a menu option
editText1 = (EditText) findViewById(R.id.editText1);
editText1.requestFocus();
editText1.setOnKeyListener(mKeyListener);
editText2 = (EditText) findViewById(R.id.editText2);
editText3 = (EditText) findViewById(R.id.editText3);
resetbutton = (Button) findViewById(R.id.resetbutton);
calcbutton = (Button) findViewById(R.id.calcbutton);
textView6 = (TextView) findViewById(R.id.textView6);
private OnClickListener mKeylistener = new OnClickListener(){
public void onClick(View v) {
if (v.getId()== R.id.calcbutton){
calculate();
else {
reset();
private void reset() {
editText1.setText("");
editText2.setText("");
editText3.setText("");
private void calculate() {
//****QUADRATIC FORMULA HERE**************
double A= Double.parseDouble(editText1.getText().toString());
double B= Double.parseDouble(editText2.getText().toString());
double C= Double.parseDouble(editText3.getText().toString());
double root1;
double root2;
double discriminant;
B = Double.parseDouble(editText2.getText().toString());
C = Double.parseDouble(editText3.getText().toString());
discriminant = Math.sqrt(B*B-4*A*C);
if(discriminant >0) {
textView6.setText("No roots");
else {
root1 = (-B + discriminant) / (2*A);
root2 = (-B - discriminant) / (2*A);
// *******should be showing answer***********
textView6.setText(root1 + "and" + root2);
public boolean onCreateOptionsMenu(android.view.Menu menu) {
super.onCreateOptionsMenu(menu);
MenuInflater awesome = getMenuInflater();
awesome.inflate(R.menu.main_menu, menu);
return true;
public boolean onOptionsItemSelected(MenuItem item) {
switch (item.getItemId()) {
case R.id.menuSweet:
startActivity(new Intent("android.jackson.com.SWEET"));
return true;
case R.id.menuToast:
Toast andEggs = Toast.makeText(myMenu.this, "Developed by Jackson Hughes",
Toast.LENGTH_LONG);
andEggs.show();
return true;
return false;
Code:
[CODE]
[/CODE]
you need your buttons to have onclicklisteners set on them,
e.g.
resetbutton
.setOnClickListener(new OnClickListener(){
@Override
public void onClick(View v) {​
// reset code in here​
calcbutton.setOnClickListener(new OnClickListener(){
@Override
// calculate code in here​
