A
Android Question
Guest
Executing tasks: [:app:assembleDebug]
Configuration on demand is an incubating feature.
:app
reBuild UP-TO-DATE
:app
reDebugBuild UP-TO-DATE
:app:checkDebugManifest
:app
reReleaseBuild UP-TO-DATE
:app
repareComAndroidSupportAppcompatV72300Library UP-TO-DATE
:app
repareComAndroidSupportSupportV42300Library UP-TO-DATE
:app
repareDebugDependencies
:app:compileDebugAidl UP-TO-DATE
:app:compileDebugRenderscript UP-TO-DATE
:app:generateDebugBuildConfig UP-TO-DATE
:app:generateDebugAssets UP-TO-DATE
:app:mergeDebugAssets UP-TO-DATE
:app:generateDebugResValues UP-TO-DATE
:app:generateDebugResources UP-TO-DATE
:app:mergeDebugResources UP-TO-DATE
:app
rocessDebugManifest UP-TO-DATE
:app
rocessDebugResources
AGPBI: {"kind":"error","text":"Error retrieving parent for item: No resource found that matches the given name \u0027android:TextAppearance.Material.Widget.Button.Inverse\u0027.","sources":[{"file":"/Users/emmanuel/AndroidStudioProjects/MyApplication/app/build/intermediates/exploded-aar/com.android.support/appcompat-v7/23.0.0/res/values-v23/values-v23.xml","position":{"startLine":1}}],"original":""}
AGPBI: {"kind":"error","text":"Error retrieving parent for item: No resource found that matches the given name \u0027android:Widget.Material.Button.Colored\u0027.","sources":[{"file":"/Users/emmanuel/AndroidStudioProjects/MyApplication/app/build/intermediates/exploded-aar/com.android.support/appcompat-v7/23.0.0/res/values-v23/values-v23.xml","position":{"startLine":1}}],"original":""}
FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':app
rocessDebugResources'.
> com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/Users/emmanuel/Library/Android/sdk/build-tools/23.0.0/aapt'' finished with non-zero exit value 1
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 13.439 secs
:app
reBuild UP-TO-DATE:app
reDebugBuild UP-TO-DATE:app:checkDebugManifest
:app
reReleaseBuild UP-TO-DATE:app
repareComAndroidSupportAppcompatV72300Library UP-TO-DATE:app
repareComAndroidSupportSupportV42300Library UP-TO-DATE:app
repareDebugDependencies:app:compileDebugAidl UP-TO-DATE
:app
rocessDebugManifest UP-TO-DATE:app
rocessDebugResourcesAGPBI: {"kind":"error","text":"Error retrieving parent for item: No resource found that matches the given name \u0027android:TextAppearance.Material.Widget.Button.Inverse\u0027.","sources":[{"file":"/Users/emmanuel/AndroidStudioProjects/MyApplication/app/build/intermediates/exploded-aar/com.android.support/appcompat-v7/23.0.0/res/values-v23/values-v23.xml","position":{"startLine":1}}],"original":""}
FAILED
* What went wrong:
rocessDebugResources'.> com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command '/Users/emmanuel/Library/Android/sdk/build-tools/23.0.0/aapt'' finished with non-zero exit value 1
* Try:
BUILD FAILED
