Help Help or Guide for flashing Spectrum to pageplus?
MunchkinB
I can't find any guides for flashing a Spectrum 4g lte to pageplus. Can someone please point me in the right direction. I've flashed a droid x and razr to pageplus. But can't find any info on this.
Most people that have tried to flash this phone to other carriers have not had much luck with it.
Unfortunately, I have to confirm trigger's statement. I've found that even most pro flashing companies out there can only get up to 1x data working.
I've found someone locally, however, who says they can get 3G working. In fact, it's being worked on even as I type but according this person, it's not do-able remotely.
Will keep those who are interested posted.
I just used a guy on ebay. He was able to get 3g and full messaging working. kinda impressed. just search for "Lg spectrum pageplus"
Whatever they are doing to get 3G working on the Spec is a closely guarded secret. I can tell you that using the DFS Tool Demo (which is free) can program the Spec for Page Plus, including the 3G authentication information needed to get data working. However, getting the 3G data to work is something I do not now how...
...my Spec gets 1X data with stock ICS ROM and CM10.x, but data doesn't work at all with stock-based "debloated" ROMs.
I m from India and using my spectrum on Reliance cdma network and using data in 1x mode and found a guy using 3g on same network and he confirmed over phone about flashing through Remotesquad . However I could not tried it because I live in a remote area where 3g signal is not available rather than 1x.
Hey guys, just a quick reminder about flashing discussions, here's a little note we've posted in a few places outlining the boundaries of said discussion here at AF:
Mod Note: By following these instructions, you are confirming that:
1) You legally own the target device being flashed and the donor device.
2) Both devices have clean MEIDs (meaning the service provider has not cancelled service to the phone for any other reason than customer request).
3) You will transfer the sticker from one device to the other to ensure that the target has the correct MEID. A heat gun or hair dryer will make this easy.
4) You will not sell your donor phone.
Doing anything other than the four criteria above is illegal and any discussion about it will be removed.
The above discussion seems fine so far, by the way :thumbup:, but thought this info might be helpful for the future.
Cheers and thanks!
