pyewhacket
Hi sorry to bother you but having a few probs with the pendo pad, android 2
1 RK2818SDK,
I need to Install a flash player for the pendo pad with android 2.1. I tried
the the android post adobe flash 10.1 flash player android now available, ( the first post to no avail, it did not work) I cant seem to
view any of the movies (that came with it -free movies app,keeps telling me
I need flash to view)
Also have the SD card and need a prog that support 2.1 most of them are for
2.2, for a apps to SD, I tried heaps and are not compatible.
Ok and I fully charged before use when I got it, noticed it gets quite warm
whilst charging and when in use, and the battery only lasted about 3 1/3 to
4 hours b 4 going flat, is that normal.
Got this through dodo, I actually thought it was going to be android 2.2
Many thanks
Vicki
1 RK2818SDK,
Many thanks
Vicki
