Since we know it is the built-in mic now there are only three possible solutions that I can think of.
- debris blocking the mic. Carefully use a pin if you can find a very fine one that would fit. But that hole is so small, if there is anything in the hole you will end up probably just pushing it in more. A suction device?
- find someone qualified (or try yourself if you know what to do) to open the phone and check for debris
- the built-in mic is simply dead/dying or there is a lose connection. You can get that repaired, but it may not be worth the price.
One other thing you can try for kicks, is to use a voice recorder app or whatever, just take a short note on the phone with the built in mic, to see if it's only when in calls, or if it's all the time. That will also eliminate the chance of it being a network congestion or any other network related issue, since you're recording on the local device itself.
i would use a vacuum before pushing a pin in the mic hole
thats a good idea. i just tried google now which has worked fine forever and...no go. seems its the hardware or could be software. where do i go from here?
