lookimback
Phone is freezing up. Don't know why. Help please. Can hardly even make this post. Keep getting apps not responding messages. Download speeds are ranging from 8kbps 2 40kbps. Tried deleting throttle files (data/system/throttle) helped a little. Carrier says everything OK on their end. Signal strength poor here but last week was seeing 350+kbps same area and w/one bar. Main problem right now is phone itself Is slow even offline. Also, is there way 2 manually stop apps from starting on boot like on pc? Im rooted and would like to edit file myself. I've tried different apps but don't know if they edit boot list or just kill app when it starts. Plus app mgr is just another app always running slowing me down.
So far I've modded read_ahead_cache changed from 128 to 1024kb init.d script automatically changes on startup. And another script somewhere maybe init.rc can't remember, makes init.d scripts run. This works fine.
Also installed 3g/4g speed optmizer. And ran another script, can't look to see what it was called. I'll edit this.(edit, script was called 3gturbocharger_installer_update.) Anyway, they seem to have helped for a minute. Short lived though.
Scanned With Norton and AVG. No viruses.
Earlier was getting low memory warning saying wifi couldn't start due to low memory. Thing is that I didn't even have wifi enabled.
Also cleared caches, cleared dalvik cache too.
Any ideas?
Any ideas?
