Root Help!! phone reboots for no reason
I was running cm7 without any problems but I saw MokeeOS and decided to try that ROM. After some time runnig Mokee I gave Ctmod a try, it was the final version.I tried to flash Ctmod using TWRP but I always got an error message, then used CWM I got the same error with CWM but after a second try it flashed Ctmod but my phone got messed up. It randomly reboots and I noticed that the power button wasn't always working, sometimes I had to charge my phone in order to be able to unlock it, I cleared the cache, dalvik cache, hard reset the phone and also re-installed Ctmod . After a week running Ctmod I flashed back to cm7 hoping that it'll fix my phone but it didn't. I even used Odin to return to stock but that didn't fix my phone either. I'm currently running the stock ROM i flashed using Odin but my phone still has the same issues. I hope someone can help me because my phone is almost useless as it is now.
Try stock without your SD card when my card started going bad it messes all kinds of Schlitz up...
