Root HELP! Phone reboots when connected to USB
torrey
I installed the vibrant4 rom, and everything ran great.
link: http://forum.xda-developers.com/showthread.php?t=743769&page=1
I decided to upgrade to the vibrant 9 rom... the phone works except if i plug in the USB... it reboots and the battery charger attempts to charge then 1sec later it reboots again, and again and again.
I want to connect this to USB so I can use Odin and restore the original rom.
Has anyone experienced this? Any advice?
link: (Rom) Vibrant9 Eclair 2.1 flashable .zip * 9/2/2010* Final * - xda-developers
In addition to this, I can't connect to Bell's data network!
I'm having the same problem. I flashed a new rom and this happened plus 3 other problems:
1) I have no audio now (except when i receive a call)
2) Vol. up and down are inverted
3) When headphones are connected, phone acts like there's no headphones connected and when there is no headphones connected, it acts like there is headphones connected. This is basically the no-audio problem.
I wasn't able to find a solution to this yet. let me know please if you do solve it, i'll do the same. thanks
