Shine 52
Member
Hi all. So 'm having some serious issues w/ the Bolt and trying to get a few more months out of it. Basically, phone boots up, goes to splash screen, then wham, phone reboots, and repeat infinitely. I can get to HBOOT. But when I try to go into recovery for instance, it does the same exact thing. Splash screen for 10 seconds, then reboot and repeat the cycle.
From doing some research, I think my only hope is to flash an RUU as a renamed PG05IMG.zip. I guess my question is, is what is this file I'm supposed to try? My radios are the one's ending in 6w_1.
Or if anyone has any further input, that would be great, but I'm pretty stuck. I think flashing saome form of PG05IMG.zip is my only hope, because I can't get any further.
Thanks.
Thanks.
