I installed PdaNet n FoxFi...on two devices ...
But Ive been watching tv shows on cartoonhd.app site with note3 and it has lots of crap that pops up, I believe it installed something. It turns off wifi, and shows those same opoup pages without visiting the site or even opening up a browser. It opens the broswer on it's own. I have to x out of it.
I already went to chrome and turned off ads, remove those 126 or so companies...some sneaky shit!
What are some steps in removing, checking, might as well learn something here before wiping it clean. I did notice when following some directions that one part, I could go no further because the box was greyed out, can't remember! Appreciate any help before having to reset!
And I have another hard drive w/ Linux Deepin 64 bit installed, never installed android console on new os! What console you recommend for Samsung note 3, using Linux? Thanks
P.S. I transferred from old azz samsung galaxy to this old azz note3 few years ago and it did NOT transfer all info in contacts, so no want to lose all that again!...was all unorganized.
Phone not rooted but issues b4 the transfer to this phone and never really used it except for emergency phone and camera! So could be old apps etc...I just dont know what to remove and what not! Dont want to F&&k it up more.
Just need some guidance and most likely clean wipe...Is there different os systems that can be installed or just root?
An ad through a browser could download an app but not install it unless you give a browser permission to install apps (which to me is obviously a bad idea). But if you are viewing stuff through an app then what permissions does that app have? It sounds quite likely that this app may be the problem (though I'm not going to install it to investigate...).
nice....crosses fingersI found something that had no name, uninstalled it, restarted phone and I think it took care of that popup!
Now to switch cards and test the wifi out! Got to stay more on top of these issues. I rarely used the phone online before, only other issues that I dislike is that if you dont update apps... things start to go haywire!
Question, anyone install Linux on Note3? Or do you recommend another OS? I like to have more control over my phone, mini pc...!
