A
Android Question
Guest
My phone went flat so I plugged in the charger, it booted u like normal, I went back to it ten mins later and it wasn't charging, swapped chargers then turned it back on, now it shows the LG screen, then switches to a battery cell which is completely grey and has a yellow sign with a black circle arrow that changes direction... any ideas? Thank you in advance
