Help Help please? Cannot connect i5700 to PC
Jeeves86
My phone would connect to my pc up to about a week ago, but i took it into the shop because of random shutdown probloems and when i got it back it wouldn't connect.
I don't get a pop-up on neither my phone or my pc when USB is connected.
i've enable 'USB Debugging mode' and searched through all the settings i can think if but to no avail :confused:
can anyone help please?
you have the same problem as me i factory reset mine and everything which failed ive now found out that it needs to be sent off to samsung or taken to a repair center you want my advice get a new phone i am cause i have now had it with this phone driving me nuts
after messing with phone for hours i thought i would try a pc i have never had the phone connected to and it worked so i rebooted pc made sure all the drivers where remove restarted pc again plugged phone in a tada bingo problem solved :)
mine is 2.2 but pc cannot detect i5700 i guess that i ned kies but it is said that kies wont reconize i5700. what to do?
Kies will not recognize 2.1 Spica , let alone 2.2 :P
P.S: Why do you need it?
