Root Help Please Installed Tool Box Pro & got a big problem
Well I installed Tool Box Pro today and I was changing the boot animation I choosed one, installed it and it rebooted well when that happens my phone gets stuck in the boot screen animation. It doesnt go away at all :(
Please help me.
That is odd. Before I made my own bootanimation, I used to change them out from ROM Toolbox all the time. There are times when changing a new bootanimation, the first time it seems to get stuck and you just pull the battery out, put back in and then you are set. It does seem that a lot of those animations last forever.....if you look at them though, some of them have over 250 pics. ROM Toolbox also puts the bootanimation in a different place. /system/data/local instead of /system/media although like I said, I've used them before with no problems, they just don't take up my entire screen and then one Doctor Who one he has in there seems to pause for about 3-4 times so I decided to make my own. Just remember, if that ever happens again, try taking the battery out and trying again, or sometimes just press your home button. After the first time, it won't happen again.
Anna
Yeah I did took out my battey but that still happened so got scared and I just reseted my phone lol. And yes it fixed my problem :D but had to install everything all over again -_-. But now Im having another problem I rooted my phone but then days later I updated it when the update finished it seems like my phone is not rooted no more is that possible ?
Oh okay. But thats the thing now when I connect my phone to my laptop is doesnt let me re-root. How come ? Can you help me please
I went to the root thread and you said it was hanging at the install part. What if they are already installed from when you first rooted?
Yeah after like 2 hours lol literally I got a pop up saying driver installed. But then when I try to run "run.bat" and press enter in the cmd I get this
[*] LG Spectrum Root Exploit (Windows version)
[*] by Dan Rosenberg (@djrbliss)
[*] Before continuing, ensure USB debugging is enabled, that you
[*] have the latest LG drivers installed, and that your tablet
[*] is connected via USB.
[*] Press enter to root your phone...
Press any key to continue . . .
[*] Waiting for device...
'adb' is not recognized as an internal or external command,
operable program or batch file.
[*] Device found.
[*] Rebooting device...
[*] Waiting for device to reboot...
[*] Rebooting device again...
[*] Attemping persistence...
[*] Cleaning up...
[*] Rebooting...
[*] Exploit complete!
[*] Press any key to exit.
are you sure you are in internet mode? and with debugging checked? drivers are installed properly? when you ran the updater tool did you have to put all your info back in like it was a new phone? did it look like it did when it came out of the box? download a rootchecker from the market, they have some free ones and check your root, or heck, if you have any apps installed that require root just click on one and see what it says.
Oh, I just remembered that did that to me once, are you extracting all, clicking on that and then clicking run? You really need to do it that way.
Anna
Do you know how can I check if my phone got rooted, becuase I ran the run.bat as adminstrator and it went through but how can I check now to be sure
Anna
Thanks Anna:) I don't have the device so my knowledge is limited. :o
Side note: nice avatar
I wasnt in internet mode I was in mass storage. When I updated my phone was like I had back then just when I restored it back to my factory setting everything got erased.
I just in case extracted it to my desktop too see and ran it in administrator and it went through well but now Im trying to see if my phone is rooted
Thanks a lot I just had to extract everything on my desktop and I downloaded root checker and showed me its rooted again :D. Very happy now lol thanks to you both.
you can use a root checker but then again you can always click on any app that requires root access. If you don't get the superuser permission dillymajig then no root, plus it will tell you that you don't have privleges to that app because you don't have root access. I have noticed when using the update tool....I use it often due to trying new things on my own phone and they don't work out quite right lol, that when Google restores my settings they restore everything exactly like I had it except for the connectivity, they don't automatically check to always ask. So for anyone in this situation don't assume because all your settings are set back correctly that ths is also.
Anna
