Used Es file explorer. It does not show an app called Photobucket (/system/app/). There are some others I cannot find (Bubblebash, UNO, etc. bloatware stuff).
Probably the reason why Super Manager says: ".apk file not found".
Must be secretly embedded some where.
Thanks.
I found the file under /data/crst/app/
Says: "cannot delete file"
I also went in the application manager and got"uninstall unsuccessful"
Bummer.
PhotoBucket's FAQ says: if app came with the providers software there is no way to uninstall it.
By the way, it did ask SU allow and remeber settings.
Maybe running A2tude modded ROM has to do with it.
My take on this is that it is similar to Bill G's Winders. "File is used by another application".
I read a lot about NAND/NOR (S-on/S-off -- NAND disabled)
I have a 2.3.5 OS that came with the crap. Rooting does not neccessarily make it S-off.
There is a source that has a hack, but only for 4G droids as I understand.
I learned to turn Data off unless I need it. Battery lasts for 5 days and no stupid rebootys and upgrades. Purpose must be to get you off the cell towers.
(Cricket/Sprint slows to a crawl after 1 Gig/mo).
