Help help please on galaxy ace
teri1986
I need some help please.
I have a galaxy ace, I have put music onto the memory card and I can listen to it but how do I get it onto the music app and how can I use it for my ringtone?
also when I connect it to my computer it just says its loaded and ready to use but wont show up ?
any help would be great
Hello teri, and welcome to Android Forums. Let's see what other Ace owners have to say about that (I've moved your question to the Ace forum area for you). :)
Hi,
If the music on your sd-card in a map called "Music" is mp3, it should automatically appear in your music (mp3) player on the phone. If you want to use it as a ringtone, make sure to create a map on your sd-card called Media, in there a map called Audio, and once again in there a map called ringtones (without capital); you can also create two other maps there, called "alarms" and "notifications", if you also want to use music as alarms or message notifications). Copy the music you want to use as a ringtone into the map "ringtones", that's it.
Finally your last question: what "won't show up" when you connect your phone to your computer? Are you using the usb-cable (follow the directions on your phone for usb-storage) or the Kies program?
