Help Help please samsung gt-i5500l
New to this and very very stuck
i have a samsung gt-i5500l
it wont start up past android logo i have tried everything i can find on the net and no luck please help
Did you try and take out the battery and put it back in after a while if that doesn't work flash to your countries stock rom and take it to the shop that you bought it from. This happened tto me the battery thing did not work for me but for a lot of people it did work, I took it to the shop that I bought it from and now it works.
not under warranty as it was a second hand fone i have tried all sorts of flash roms etc has any 1 got a link to help me get this sorted i need this fone asap to use
