NullPointerException is a RuntimeException . In Java, a special nullcan be assigned to an object reference. NullPointerException is thrown when an application attempts to use an object reference, having the nullvalue. These include: Calling an instance method on the object referred by a null reference.
I would uninstall FB and re install or If you can't uninstall,Clear cache/data to FB app.
And try and login to FB again.
