Help Help Please
mchisy
Hi all
Can anyone help please..........
Im pretty new to the Android scene and im having a problem with my G1, i bought it a few days ago secondhand and all was working fine on it till i updated to 1.6 and now i cant get wifi to work properly its just says "unable to start wifi" and on the very odd occasion that it does work, it will work for a few mins then the phone will lock up and then it just goes to the screen saying "Androind"
As far as im aware the phone is not rooted and its unlocked to all networks, it was originally on t-mobile.
Cheers
Hi all
Cheers
First I have moved your post to the G1 forum ...
you need to give us more information ....
1.) Model Number ? T-Mobile G1
2.) Firmware Version ? 1.6
3.) Baseband Version ? 62.50S.20.17U_2.22.19.26I
4.) Kernel Version ? 2.6.29-00479-g3c7df37 android-build@apa26 #19
5.) Build Number ? DRC92
Also do you have a T-Mobile Data plan on your
PayAsYouGo or FlexPay Plan? ________NO________
Carrier ? UNLOCKED (we know some are also Unlocked so not Just T-Mobile)
Country you are using your phone in ? _______UK________ (we know that not everyone is from the US)
