I had to manually update these settings when I first got my phone.
Setting>About Phone>System Updates> Update Profile
That may work. When I activated my Prevail I had to manually enter the settings to activate it, and I had to update my profile.
The profile is a list of services your phone is allowed to utilize on the boost network.
Can you place calls with the phone?
Edit: Have you checked your activation status
https://apps.boostmobile.com/boostApp/checkStatusDisplay.do
I got my phone a week before I activated it so I just played with stuff on wifi, and killed the activation process every time it came up.
When it was finally time to activate I couldn't make the phone run the activation, but after your activation status is confirmed there should be an option and instructions on how to activate it yourself. I don't remember the steps, but this may help?
last resort (but the simplest): I suggest calling boost and having them run you through the activation/ profile issue.
so i should call boost customer service and tell then my phone doest have network service right? or what should i say because i called today and all they did was made me reset my profile which is what brought the activation back,
If you just bought the phone on the 22nd , take it back . I would . You may have a hardware issue . Most places will activate the phone right there on the spot if you ask them 2 . Once your phone is activated , you should have 3g .
NOTE: I just re-read this thread and I don't see anything where you have went in to setting and turned on the 3g service . Menu/Wireless and networks/Mobile networks . 3g data should be checked ........ If it is checked and you still don't have 3g , return the phone .
3G is activated , everything is working fine with the phone because i bough it from a friend and when he had it everything was working , i guess i just have really bad luck?![]()
Glad you got it fixed .![]()
