help please!
roeee
The texting app the came preinstalled on my LG vortex has disappeared and now I cannot send or receive any pictures. Is there a way to install the APK again and how do I do so. Please help, thisss is very frustrated
I have LG Optimus phone.. and when this kind of problem happens then i generally do factory settings reset..
Warning : that will delete app data and apps from your phone but you will get all pre installed apps back..
Welcome to Android Forums, Roeee!
Are you sure you removed the app or just the shortcut on the home screen or launchbar?
If you go to your app drawer, is the messaging app still there?
That is why I do not get as to why there is no quick search tool kind of like with what windows has as well as what Linux implemented. Or should I say Linux implemented it first then windows fell suite with the idea.
