slinkydonkey
Hello
I have an original HTC Desire to be honest I think its a great mobile apart from one major issue which almost makes it un-usable its complete lack on onboard memory.
For this very reason I upgraded the mobiles ROM from a standard Vodafone UK OTA ROM to Oxygen-2.0-RC7 but I want to remove it and put something on that is 1 better 2 does OTA updates 3 works 4 Im not the sort of geek who can spend days trying to get something working so maybe going back to stock would be best.
I dont know what Vodafone UK are currently up to Andriod wise but think maybe I should go back to stock as I will again get OTA updates when the OS is updated something that I dont get at the moment.
Instead of using Vodafone stock ROM isnt there a generick google ROM with OTA I can use?
My only concern is that will I have to UN root the phone?
Will I loose all ability to transfer apps to the SD card?
I would like to get this done today so any replys would be very very much appreciated.
Cheers
Paul
Cheers
Paul
