Help Help Please
hey guys
my htc woldefire s dosen`t sync facebook & twitter for HTC sense accounts at all i tried to install FriendCaster for fb account sync & it worked but twitter no, and i wanna to sync my contacts from facebook & twitter for HTC sense so please any help ?
There are three places to check to make sure sync is installed by I can't help you with details because I don't own the Wildfire S anymore.
1. Make sure sync is enabled on the device. I always did this through the power control widget.
2. Make sure sync is enabled for individual apps. This is done (if I remember correctly) through Settings > Sync. You'll see all the apps that use sync listed and a sync icon next to them. If sync is enabled for that app, the icon will be blue or green. If not, grey. Click on the app's name or sync icon to change settings.
3. Once in the app there may be additional sync settings in its settings menu.
Hope that helps!
