the phone keeps rebooting and says some words in the screen that are too fast for me to read and then reboots
i used the 3 finger method and i go into CwM Voodoo lagfix Recovery v2.5.1.X which i appiled the following:
- wipe data/factory reset
- wipe cache partition
- wipte dalvik chache
and then i tride to reinstall the Cm 7.2.0 fascinate ( still in CwM Voodoo lagfix Recovery) and i get a ( status 7) installation abort
I installed notepad+++ and got rid of the coding that denies the install, now the Installing update is still on update
i cant get into clockwork because it keeps rebooting...
also i get this when im in CwM Voodoo lagfix Recovery
CwM voodoo lagfix recovery v2.5.1.x
E:cant mount /dev/block/stl11
(file exists)
E:cant mount CACHE:recovery/command
(file exists)
E:cant mount CACHE: recovery/log
E:cant open CACHE: recovery/log
(file exists)
(file exists)
(file exists)
(file exists)
