how do u get bbm on htc desire hd,my android version is 2.3.5 and when i click on the bbm link to downlord it ,it says you device isnt capatble ,can someone help me plz
Hi!
If your phone is not compatible then you can't use the app. Your best bet would be to find a similar app that is compatible with your phone and use it. Hope this helps!
