HELP PLEASE !!!
I currently rooted my sprint galaxy s6 edge and attempted to install twrp recovery from the flashily app. Now it will only boot into a white and green twrp loading screen and their is not a stock firmware released for my phone yet? Is there any way I can fix this without the stock firmware? How long will it be until the Stock firmware is released? Please Help, Thank you!
Download and install the latest Samsung Phone USB drivers on your PC. Then hold the volume down, home and power buttons simultaneously and your phone will go to a blue screen. Then press volume up button and you will be in Download mode. Then start ODIN on your PC. Now connect your Edge and ODIN should recognize it. Now using ODIN you may either flash the stock Recovery back onto your phone or flash the ChainFire Autoroot for S6 Edge. Flashing either one of these files will reboot your phone to the normal home screen.
