Root help! please!
djbasik
Member
okay. So...
I created the gold card.
Downgraded.
Rooted.
Now im trying to install a ROM. I decided to try SenseHero first.
Install went okay. no errors.
when finished i sleected reboot from the recovery menu. my phone reboot. I hot the hero boot screen then changed to the sense hero boot screen with the blue bar animated. for a while. then it freezes.
I did not do a whipe first for 2 reasons. When I went to wipe i have multiple optons.
Factory/data reset wipe, dalvik-cahce, sd:partition, battery stats, and rotate.
When i tried dalvik it gave me "error: Run 'wipe dalvik' via adb.
i tired it a second time but still gives me the dalvik error.
should I be doing a data/factory rest instead?
lets say I cant get this to work... how do i restore to factory?
UPDATE!:
I have successfully installed Villian10 BUT!
I have no data network services. My 3G/HSDPA does not work. It does connect? there is nothing in the notification bar, and no data coming into my phone. WIFI works though.
doe any one have any suggestions.
thanks for the help peeps!
UPDATE 3!: :)
Okay So I have now successfully rooted.
installed my first ROM.
AND! got my data services now working.
For those of you who are having trouble with your data services on Telus. try theses APN settings.
menu>settings>wireless and networks>Mobile Networks>Access Points Names>menu>New APN
fill in the settings below. anything you dont see below isnt really needed for it to work, leave those fields blank.
Name: anything you want. I used Telus.
APN: sp.telus.com
No username/password
MMS APN: sp.telus.com
MMSC: http://aliasredirect.net/proxy/mmsc
MMS Proxy: 74.49.0.18:80
Tethering APN: isp.telus.com
Telus APN settings don't work - xda-developers
When switching between different ROMs you should do a factory reset, wipe the dalvik-cahe and the ext parition. Unless you're just updating the same ROM (e.g. Villain 10.0 to 10.1).
does any one have any tips to help with battery life? I notice that my battery is being destroyed on Villian10
You should download the overclock widget from the market. Despite the dangerous sounding name, you can use it to run the processor at a slower rate when the screen is off. It doesn't affect performance but does help battery life.
You can have it speed up the processor when the screen's on, but obviously that won't help your battery :D
