Help help please
mukundrA
I tried to root my lenovo s580, now it stuck in lenovo logo. Androi recovery mode showing no command. What should I do? System partition chevk showing system have been root.
What root method did you use? Can you get it flashmode connecting to computer? Did you get as far as putting a custom recovery on it? If so can you get to that and reflash backup (if you got that far)?
By downloading Kingroot app to your phone or using the Kingroot PC software? Did you just attempt to root and it reboot itself and straight into Lenovo screen? You won't be able to flash a custom recovery at this point as you will need to be able to get into the UI and have root properly installed first.
I can find very little for this device and I have no knowledge of Lenovo phones. Can you get into any recovery / flashmode / download mode etc? Usually by holding down one or two of the physical buttons while booting. Have a search if you can find any of these modes for that device, or trial and error.
I can flash to android recovery mode. It showing no command, there is a option callled system partition check, after click on that option its sjowing system have been root
