softpinkishlips
Member
i just upgraded my firmware from JPA i think to JPE. after upgrade my fone now is useless. it doesnt open. pls help!! did i brick my fone>???? pls help me bring my fone to life again
what happens when you turn it on? does it stay stuck on the boot screen (the one with galaxy s rainbow or whatever)?
that happened to me too. what you need to do is do a factory reset in the recovery menu. do you know how to do that?
with you phone off, press and hold VolumeUP+Home+Power. Once it reboots, release the buttons. There you will find the options "reboot", "apply sdcard:update.zip", "wipe data/factory reset" and "wipe cache partition".
You can navigate the recovery screen using VolumeUp & VolumeDown and use the Home button to select.
Choose the "wipe data/factory reset" option.
WARNING: this will restore your phone to the original configuration of the firmware YOU LAST INSTALLED (including any updates made via update.zip). This will NOT bring your phone back to the firmware installed when you originally bought it unless you haven't flashed your phone. You will lose all your data and apps ok.
---THanks to DarkStriker from the XDA forums for this.--
If you have further questions, just tell me. Good luck!
i pressed the 3 buttons but i got the yellow sign digging. what's next? its been there for hours already.
