I ve SE X10i and have super user installed ... i want to ask u is there any problem in formatiing my phone with installed super user or do i have to uninstall superuser??? and in case how to uninstall super user ?
So you want to do a factory reset? If you do, any apps will be removed, except for the ones that came with the phone. So you will have to re-install superuser once you reset. Also, I'm not sure about your phone, but most phones will unroot you when you do a factory reset.
