Root help plz - Android 1.6 Apps2SD+SSHD Korean rom
zipman
i have rooted my lg eve with Android 1.6 Apps2SD+SSHD Korean rom from Android 1.6 Apps2SD+SSHD | Zac's Pad it installed fine, boots fine, seems to run fine but when i restart the phone i have to do the whole setup over and over any one know a way to fix this?
this is what i do.
turn on phone i get the Korean menu, i click next then put it in english then time and date then setup is finished it give a thank you screen, if i now restart the phone all the setup is set back to the setup screen again all appz and every thing,
thanks for any help,
oh and i have tryed all other systems and boots the only other one that worked was system V4.2 that also kept resetting info after restart of phone,
