Help plz
Mmay
Hey, my phone had a low battery, it was red, the phone just switched of now when I turn it on it will only show a htc logo and the White background, it will make the noise but it's stuck on a loop. :( what should I do?? By the way the phones a htc wildfire s
Remove and reinsert the battery, then connect the charger and leave until battery fully charged. Also, you will want to check in with the other users of this device over @ its area of support.
Tap link below:
HTC Wildfire S - Android Forums. Best of luck. :)
Welcome to the AF, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
