xclusive36
Android Expert
I've been attempting to build cyanogenmod for the Optimus f3 Virgin Mobile phone.
There is no custom rom for this phone. Only stock roms. The current android version is 4.1.2. I haven't had allot of luck with cm-10 but I've had some good luck with cm-10.1
I'm building from source and am using 2nd-init to bypass the locked bootloader. I can get it to load the boot animation if I copy over the full stock lib folder. Otherwise I run into dalvik issues
Here is the current logcat
How would I get passed the build rev issues? Would the answer be as simple as needing a 4.2.2 libdvm.so lib file? I would appreciate all of the help I can get.
My git device tree is here
It's slightly incomplete. It doesn't have all of the pre-built files from the lib folder. I haven't included them all yet into the device tree.
Here's the current thread:
Thanks in advance
E/dalvikvm( 307): DexOpt: build rev does not match VM: 27 vs 28
Thanks in advance
