Help Help! Potential keyboard issue
RAndrews
Hi, hope someone can help. This is my first time posting on these forums so hopefully I've come to the right place!
I've recently upgraded to version 4.4.2 on my Galaxy S4 Mini & have come across a potential issue when composing text messages.
I understand this version allows you to use emoji's - i rarely use them but have noticed that after using them, the message is converted into an MMS (which is fair enough) but then, the text i enter into the keyboard isn't recognised - that is, it's not recognising individual words (for example, "hello" appears as "gdjjm") and i have to repeatedly press the "back" button to change it back into a normal text message and go back to the keyboard.
The solution is simple, not to use emoji's!! Very often, the keyboard stalls then takes me to the emoji screen by itself, it's annoying to repeatedly have to press the "back" button to enter text.
Has anyone else spotted this, or does anyone have any fixes/work arounds?
Many thanks.
Actually, this is the Note 4 forum, not the Galaxy S4 forum. A Moderator can move this into the correct forum for you.
