this has been a recurring problem for me
when i flash a rom, everything will be working fine, but a few hours later (after playing around w settings/restoring apps, etc) long-pressing the power button stops working!
i can still turn the screen on and off, but when i try to get to the power off menu, my phone freezes. the only way to fix it is a battery pull.
any ideas on what is causing this??
more info- i use rom manager to flash roms and have been using jt's super clean, and blackhole. kernel is jt's stable 11/11 kernel. i switch back and forth whenever i'm feeling up for re-doing my phone, hoping the clean start will fix things ! but alas, mere hours later, the power menu ceases to function. sigh
p.s. having to do battery pulls irk me!!
