Help HELP problem needed serious battery drain on Nexus 7 2013
Ok, I am new to this forum, but I know that this is designed for android users and you guys can probably help me out or share similar experiences with your N7 2013. So, I realizes the battery goes down very fast on my Nexus 7, even faster than my dad's. So I decided to conduct a test, overnight I made sure they were both wifi disabled, same brightness and sound (though it wouldn't matter since it's in sleep mode), disabled notifications, all at the same settings and all started from 100%. This morning, my dad's Nexus 7 was 96 percent while mine was 88 almost 87 percent. It dropped massively doing nothing in sleep mode. And it couldn't be an app cause the ones that causing it is table idle. I don't know, so I checked with an app, and they both were 4.2 , 3950 mah battery, about same temp, etc. So is it because my tablet has a damaged/defective battery of some sort so something else? I'm really nervous about it.
