HI.
So I have only had the Avant for about 5 days now.
Kit Kat 4.4.2 version..
I have been getting familiar with it since then clicking on different apps and things just to get more acquainted with the phone and all it has."
Today I clicked on the software update button in my phone settings.
I thought after I clicked on "software update" that I could read what updates were available, if any. Instead, it said that there was an available update and started downloading a 100+ MB file. there was no option to cancel or stop this file download.
After the file downloaded, it asked me if I want to install, or postpone the update an hour, 2 hours, 6 hours, etc..... I think I chose the 12 hour to postpone so that I had time to find out what the update is about. There was a bunch of warnings that came with that message about that it is a 10 minute update and I can NOT use the phone at all during the update period. Not even 911.
I chatted with Tmobile and they recommend I do it & at one point there would be a notification that there was an available update. They said it is the 4.4.4 update. I told them that I wanted to delete, cancel, stop, etc the update. She said to remove the battery and /or disable wifi. I told her that it said to absolutely not to do any of that if the update has started.
SHe assured me that it wont hurt the devise at all.
Well I am not gonna take her word for it just yet. I would rather let the update go thru, than have my new phone ruined.
If you ask me why I want to stop my phone from getting 4.4.4 now, it is because I dont want to update something that is not giving me problems. I have had a couple of good apps running on my phone that I liked that got updated, only to find that they stopped working.
I can get other apps, but I dont want to update something until I know more about it. I read that the update causes the battery to drain faster afterward. But, I would like your input please.
" My main questions are HOW do I safely uninstall the download file that is associated with this update. Is it possible? Is it safe to uninstall? Do you recommend the update?
Thanks in advance......
Sorry for the long post but I had to explain.
