Hi,
First time posting here and I've looked everywhere across the web to try and fix this simple issue I'm having but no success. I just got my galaxy s3 yesterday and I wanted to know how to change the shortcut icons located in the quick access panel at the bottom of the homescreen. I've read different methods. I've tried simply holding the icon and dragging it onto the home page but that doesn't work for me no matter how long I press and hold the icon on the short cut tray it just doesn't let me drag it around. This was the method that was instructed in the manual as well so hrmmm. Also I've tried going into the app tray hitting the menu key > edit but the quick access panel disappears so i can't drag an app onto there. I don't wanna install any other launchers I'm just gonna stick with touchwiz for now.
Thanks.
Thanks.
