Help help quitting skype
I've installed skype,
but i can't seem to exit it.
the backbutton doesn't work and advanced task killer doesn't see skype.
At the top left corner, i can see skype is still runnin when i use the home button to get back home.
how can i quit this app?
there is nothing in menu except "add" and "groups"
i figured out if you set your status to sign off, that works. but is that the only way?
