Help Help Razr Maxx
crashdogy
Need help with my razor maxx it had been working fine for about 2 mouths. It started to get slow and the widgets where laggy when I touched them, and my live wallpaper keep freezing up I also have some reboots. So I un-rooted and went back to stock NO change. It is acting the same way, I have tried factory reset, cache wipes, no viruses , no malware, system clean, try it in safe mode same issues, new update .215 and factory reset again. Its fine and working ok for about 20 minutes may be 30 mins after reboot but then have the same issues any ideas or help greatly appreciated ?​
Yes I did and no SD card, but I think I got it working now been up and running for about 13 hours now no reboots or freezing up. I’m not sure how I fixed it but the last thing I did was I went into fast boot and selected option #6 and rebooted it, did seem like it did anything but it’s working now. Thanks for the help
I don't thinks I'm using the SD card now with no issues and had it back in when I did the option #6 hale Mary LOL ! its weird
Power off, hold power button, and both volume buttons until it gets to the boot menu and use the volume down to get to fast boot and use the up volume to select
Does anyone have info on fast boot option #6 and what it does because if I boot normal have all the same issues. If I boot using option #6 in fast boot menu it works fine it must change something ?
