Help Help! Rebooting nightmare!
nemz90
So I've only had my phone for a couple months and it worked like a charm until now. It's been rebooting it's self like crazy! I have no idea why. so I uninstalled my most recent app and it's still acting up. I took a look through all my apps and there was a specific one called error 1.0.0. Don't know what it is! I'd like some advice on what I should do about this! Please and thank yous. :smokingsomb:
OK, what version of android are u running(GB/ICS/JB)? Have you rooted the phone? With more info I can definitely help u out of your situation.
Hi
I dont know if this will hlp but you might take a look into it.
I heard somewhere that depending on the android version 2.3.X I guess, If you use a low speed SD card and install apps there, sometimes this tends to reboot the phone. This might be caused by the speed of the SD. It should be a faster SD for it to hold apps.
I'm sorry I dont have a really detailed explanation or to even verify this (I dont really have the time for that at the moment), but I guessed it might give you a direction where to look
Hope it helps
I'm having the same problem as the OP. I'm running stock ICS through Kies, unrooted. I could really use some opinions. Factory reset did not solve the problem. I suspect an app, but how can I tell which one is the offender without removing them one by one?
