I'll try to be brief...
Background: I bought a used Samsung Galaxy Tab knowing full well that there was something wrong with the internal 2GB memory. The previous owner had installed CM10.1 nightlies on the SD card and was booting the tablet from the external SD card, totally bypassing the internal memory.
The goal: to recover the internal memory
Steps I've taken:
1. Removed external SD card so it doesn't boot from SD card
2. Successfully used Heimdall to re-flash to stock (VZW 2.3.5 Stock Root) - after the flash the tablet attempted to reboot. It went to the VerizonWireless screen and I think went into a bootloop.
3. Turned off the tablet and booted into the stock recovery. From the recovery menu I tried to reboot the system, which gave me the following error:
"failed to mount data"
4. Turned off the tablet and booted into stock recovery. I wiped the cache partition. Then I tried to wipe data/factory reset and got the following error:
"E:failed to mount /data (Invalid Argument)
E:install_application_for_customer: Can't mount /data
your storage not prepared yet. please use UI menu for format and reboot actions"
5. Using Heimdall I successfully flashed ClockworkMOD recovery, and booted into CM recovery.
6. I attempted to reboot system now and the tablet just hangs at the Samsung logo, doesn't even go to the Verizon screen.
So obviously there seems to be a problem with the /data partition. I'm not sure exactly what to try at this point. How do I mount /data? Can this be done from within CM recovery?
Any advice or things to try would be greatly appreciated.
Steps I've taken:
