shreya_wip
Need small help regarding map view and overlay.
i have map activity and also showing markers using ItemizedOverlay.
My problem is i want static image for mapView i.e my map should not be zoomed and i should not be able to drag it also. But when i tapped on marker it should display some toast or dialog.
below is sample of my code
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.activity_main);
RelativeLayout rv = (RelativeLayout) findViewById(R.id.relative);
LinearLayout ll = new LinearLayout(this);
ll.setOrientation(LinearLayout.VERTICAL);
rv.addView(ll);
int lenght = addressAndPhoneNos.length;
for (int i = 0; i < lenght; i++) {
TextView header = new TextView(this);
TextView blank = new TextView(this);
phoneNo = new TextView(this);
TextView addr = new TextView(this);
header.setText(addressAndPhoneNos[0]);
ll.addView(header);
addr.setText(addressAndPhoneNos[1]);
ll.addView(addr);
phoneNo.setText("Operator: " + addressAndPhoneNos[2]);
phoneNo.setClickable(true);
Linkify.addLinks(phoneNo, Linkify.ALL);
ll.addView(phoneNo);
blank.setText("");
ll.addView(blank);
Button direction=(Button)findViewById(R.id.direction);
direction.setOnClickListener(new View.OnClickListener() {
private Uri uri;
public void onClick(View v) {
double latitude = 12.306080;
double longitude = 76.656432;
uri = Uri.parse("geo:" + latitude + "," + longitude +"?z=10");
Intent intent = new Intent(Intent.ACTION_VIEW, uri);
startActivity(intent);
// Intent myIntent = new Intent(MainActivity.this, LaunchMapActivity.class);
//MainActivity.this.startActivity(myIntent);
}// end of onClick
);// end of setOnClickListener
mapView = (MapView) findViewById(R.id.mapView);
mapView.setFocusable(false) ;
mapView.setBuiltInZoomControls(false);
/* mapView.setOnTouchListener(new View.OnTouchListener() {
@Override
public boolean onTouch(View arg0, MotionEvent arg1) {
//Toast.makeText(getApplicationContext(), "mapView touch", Toast.LENGTH_SHORT)
// .show();
if (arg1.getAction() == 1) {
mapView.setClickable(false);
return true;
else
mapView.setClickable(true);
return true;
List<Overlay> mapOverlays = mapView.getOverlays();
Drawable drawable = this.getResources().getDrawable(
R.drawable.marker);
MapItemizedOverlay itemizedoverlay = new MapItemizedOverlay(drawable,
this);
mapController = mapView.getController();
int minLat = Integer.MAX_VALUE;
int maxLat = Integer.MIN_VALUE;
int minLon = Integer.MAX_VALUE;
int maxLon = Integer.MIN_VALUE;
List<GeoPoint> geoPoints = new ArrayList<GeoPoint>();
int geoPoints_length = latitudeLongitude.length;
for (int i = 0; i < geoPoints_length; i++) {
GeoPoint point = new GeoPoint((int) (latitudeLongitude[0]* 1E6), (int) (latitudeLongitude[1] * 1E6));
geoPoints.add(point);
OverlayItem overlayitem = new OverlayItem(point,
"Title for dialog", pinAddress);
itemizedoverlay.addOverlay(overlayitem);
for (GeoPoint item :geoPoints)
int lat = item.getLatitudeE6();
int lon = item.getLongitudeE6();
maxLat = Math.max(lat, maxLat);
minLat = Math.min(lat, minLat);
maxLon = Math.max(lon, maxLon);
minLon = Math.min(lon, minLon);
double fitFactor = 1.5;
mapController.zoomToSpan((int) (Math.abs(maxLat - minLat) * fitFactor),
(int)(Math.abs(maxLon - minLon) * fitFactor));
mapController.animateTo(new GeoPoint( (maxLat + minLat)/2,
(maxLon + minLon)/2 ));
mapOverlays.add(itemizedoverlay);
in
public class MapItemizedOverlay extends ItemizedOverlay<OverlayItem>{
public boolean onTap (final GeoPoint p, final MapView mapView){
if (super.onTap(p, mapView)) {
return true;
else
//mapView.setClickable(false);
return false;
@Override
rv.addView(ll);
ll.addView(header);
ll.addView(addr);
blank.setText("");
ll.addView(blank);
private Uri uri;
}// end of onClick
@Override
// .show();
return true;
else
return true;
R.drawable.marker);
this);
in
return true;
else
return false;
