Help Help regarding size of the Transformer Prime
Hello.
I am thinking about replacing my Asus eeePC and getting the Transformer Prime instead. This is mainly because i can't write properly with the eeePC because the keyboard is so small.
I have seen a size comparison between the iPad 2 and the Prime and it seems to me that the size won't be a problem but i have only roughly measured it.
Does anybody have a eeePC and the Prime and can tell me if the keyboard on the prime is bigger and if it's easier to write on.
Hannes
I have an Eee PC 1018P which is strikingly similar to the prime w keyboard. Its even brushed aluminum. The keyboard looks extremely close to the size and layout of the prime's. It's taken me quite some time to get used to the keyboard on my eee pc, so I'll be fine w the prime (which I really want). I want the prime b/c it can do more than my netbook. Thinking about keeping my netbook too though b/c I upgraded the ram to max and put a ssd in it and its screaming fast now. Guess I'm just a gadget addict.
