Help removing MIUI and installing Android
ahmerin
Hi there,
I am in a desperate need of help. I have looked around but could not find answers to my problem.
I have the following problem:
I purchased a second hand Samsung Galaxy S2 from a shop today. I had Samsung Galaxy S before. This new set has MIUI running. I want to go back to standard android that comes with the phone. My main reason for this is that I took a backup of my old phone, using kies, and now I can not restore my contacts etc back to the new phone because Kies can not be used with MIUI.
I am new to playing with phone's OS and will appreciate if someone could guide me to simple steps of restoring the phone back to its original OS where kies can be used. I will appreciate if someone could tell me from where I can download the OS (which version) and how I install it.
The new phone did not come with any CD or any backup OS files. In other words, I have no files that I can use as a base to install the previous version.
Thanks in advance for your help.
Kind Regards
Ahmerin
How to restore stock firmware on Samsung Galaxy S2? (Video)
How to restore stock firmware on Samsung Galaxy S II? That’s the question that you going to ask before install custom firmware. Or after installed custom firmware and need to send your Samsung Galaxy S2 for warranty service. You need to make sure that your Samsung Galaxy S2 can restore back to stock firmware just like it arrive at your hand in the very first time. Else Samsung Support might not accept your Samsung Galaxy S2 for warranty claim. But some said that Samsung Support do service Samsung Galaxy S2 with custom firmware. Anyway, there is a way to reinstall back stock firmware on Samsung Galaxy S2. Just follow below step by step video guide. No harm to return everything to stock, right? No question will be asked by Samsung Support then.
Prerequisites
  • Odin3
  • Stock Firmware
  • USB Jig
Step by Step Guide
  1. Press and hold down Volume Up + Home + Power buttons at the same time.
  2. Release all buttons when you see SGS2 Logo.
  3. ClockworkMod Recovery or stock Recovery Mode will be loaded then.
  4. Select wipe data/factory reset.
  5. Then select Yes — delete all user data.
  6. Turn off your phone after that.
  7. Press and hold down Volume Down + Home + Power buttons at the same time.
  8. Press Volume Up button when warning prompt.
  9. Odin download mode will be loaded.
  10. Connect USB cable to your phone.
  11. At PC, extract the stock firmware .tar file that you downloaded to Firmware folder.
  12. Then bring up Odin3.
  13. Click on PDA.
  14. Select the .tar at Firmware folder.
  15. Click Start then.
  16. Remove USB cable from your phone when you see green PASS! at Odin3.
  17. Android OS will be loaded.
  18. Then follow phone onscreen instructions to setup.
  19. Turn off your phone.
  20. Plug in Micro USB Jig to Samsung Galaxy S II.
  21. Odin download mode will be loaded.
  22. And Custom binary download counter will be reset.
  23. Remove USB Jig and reboot your phone.
  24. That’s all.
Yeah… Your Samsung Galaxy S2 should be back to stock firmware after you done everything as above. No need to worry about warranty claim now.
Download Odin3 v1.85 here.
Download official Samsung Galaxy S2 firmware here.
Thanks a lot...
I have managed to get the original software back... Could not reset the binary download counter as I do not have USB jig... I hope there will be a software to do this trick...
Thanks once again for your help.
Regards
