Root HELP! Require apk for date/power bar in notification bar
Artyem
Guys I just deleted the upper part of the screen that shows the time date and small widgets on the screen. I don't know the name and how can I install it again? Help pleeeeeeease!!!
Are you rooted Artyem? If you're not, then you most likely didn't delete the app.
Do you mean the time date and power bar in the notification bar?
Are you on Gingerbread 2.3 or Froyo 2.2?
If it's a widget, then just long press on the screen and at the bottom, scroll to the widgets that you want.
My friend you are right it is the bar on the top. My phone is rooted and I thing I uninstalled a kind of application but i dont know which one Help please if you can,
Hi Artym, I've moved your thread to the Root section so that someone with root can assist you. I've also changed your thread name to be more reflective of your issue.
You can give more details so that others can help you. What version/build of the SGS do you have (international?) and what OS are you currently on?
