Z4root is the simple way to root your device.before rooting device do factory reset wipe all installed data,wipe catch.how to wipe data and clear catch, first switch off the device.press volume down key with power switch together for 2 second. device will be in recovery mode.after wipe data wipe catch reboot device.
now open settings/application settings/ [tick] unknown sources/development/ [tick] usb debugging. now go back settings/wireless & network/ [tick] airplane mode because while rooting some times we get error coz network interface. so do rooting safely. now install z4root open it you find two options temporary root and permanent root don't click temporary root this may hang up device with micromax logo.so click permanent root. wait for a second your device will now rooted it will automatically reboot once.now enjoy your rooted device.if you want to unroot click unroot from z4root... hope this may helpful for all new rooting devices..
here is the working original updated z4root v1.3.0.. link below [APP] z4root - xda-developers
