Help Required Pls
jabba1812
Hi I am a total novice and just got my first Android phone, a htc hero g2.
Could someone pls tell me were i can get a free sat nav app from and how to load it to my phone from laptop. WOuld be helpful if basic instriuctions im not that good on this phone yet
thanks
You most likely already have Google Navigator installed on your phone. Open your app drawer and scroll to the N's. Look for a blue arrow that says navigation. It may be called something else if you got your phone second hand, so it might be best to check with the members who have the same phone in HTC Hero - Android Forums
Apps should be installed directly from the market (no called Google Play). Downloading files directly and installing is not safe.
