phoenixdog
i've installed launcherpro plus v0.8.6 and placed a sticky note on one of my blanks sreens. somehow i resized it to cover the entire page and now i can't seem to resize it down or trash it. any suggestions?
I have not used LauncherPro in almost a year but if the function hasn't changed, all you need to do is long press on the widget and you will get an option to resize it. Then drag it to your desired size.
If you want to trash the widget, simply long press on the widget and a little garbage can will appear at the top (or bottom of the screen). Simply drag and drop it into the garbage can.
The only thing I can think of would be to add a blank screen then long press the sticky note and drag it to the blank screen. Now go back into the lpp preferences and homescreen settings and change your screen count down to one less and it will delete the newest added screen and whatever is on it
Im not sure what you mean by the whole screen turns.
how you switch from one screen to another.. i've got 4 or 5 screens including home page and this sticky note is taking up one entire screen. cannot resize it nor can you drag to the trash bin
