Root help root 4.1.2 razr maxx
N00Bi
hey guys new here. trying to use motochopper to root my factory stock razr maxx. ive tried a few times and this is what i get
[*] Motochopper: Android root exploit (Windows version)
[*] v1.0
[*] by Dan Rosenberg (@djrbliss)
[*] Tested on the Motorola Razr HD, Razr M, Razr Maxx HD, and Atrix HD.
[*] Supports lots of other devices as well. ;-)
[*] Before continuing, ensure that USB debugging is enabled, that you
[*] have the latest USB drivers installed, and that your phone
[*] is connected via USB.
[*] WARNING: This will likely void the warranty on your device. I am
[*] not responsible for any damage to your phone as a result using this
[*] tool.
[*] Press enter to root your phone...
Press any key to continue . . .
[*] Waiting for device...
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
[*] Device found.
[*] Pushing exploit...
2316 KB/s (1283460 bytes in 0.541s)
[*] Pushing root tools...
1796 KB/s (91980 bytes in 0.050s)
2163 KB/s (1867568 bytes in 0.843s)
2099 KB/s (969701 bytes in 0.451s)
pkg: /data/local/tmp/Superuser.apk
Success
[*] Rooting phone...
[+] This may take a few minutes.
[-] Failure.
[*] Cleaning up...
[*] Exploit complete. Press enter to reboot and exit.
ive tried a few other root tools but they all seem to fail. ive made sure to have the most up to date drivers and have my usb debugging enabled
can anyone give me some instruction on what to do next?
thanks for your time
I know one of the more senior members will jump in here and help you. I think they are going to need your build number to give you the best advice. I believe Motochoper only works prior to the most recent OTA. There is a work around Root method out there if you are running the latest stock OTA -- You just won't be able to unlock the bootloader. The work around root method isn't too hard to find with a web search. Good luck, we n00bs have to stick together!
